580B backhoe
Tim
05-27-2003 13:41:10
I have a chance to buy a 1980 580B for $3500. It runs and looks very clean. Owner says it has a engine knock that developed after he rebuilt the injector pump. He had another guy redo his work and the knock got better but its still there.
I have seen alot of 580B's in my area for 7 to 10K
So even if I have to do major engine work is it worth it?
Question#1
Case get $331.00 for full shop manual. Are there any other options to get a manual.
Question#2
how much does it weight? not (4WD) (not exhoe).
188 diesel engine.
Any input would be great.
DaleIN
05-28-2003 14:21:01
 Re: 580B backhoe in reply to Tim, 05-27-2003 13:41:10
Tim, as long as its not hydrostatic drive, sounds good to me. The 580Bs were built from 1971-75 or 76, depending on which serial number book you believe. It'll weigh close to 6 tons.
tim
05-28-2003 15:16:02
 Re: Re: 580B backhoe in reply to DaleIN, 05-28-2003 14:21:01
Thanks for the post Dale
I talked to a guy at the factory today. He said it was a 74'
It is a shuttle shift.
Another guy at the dealer said a knock that showed up on start up could be a bent push rod cause by using ether.
I am going to buy it this weekend..
