'52 SC Hydraulics contamination
Crispin
05-28-2003 07:45:22
'52 SC is running good and now I have to clean up the hyd. system. A line has been missing for 15-20 years and the system spews out milky oil. What is the best way to fix this condition? Should I take the pump off the tractor? Flush? Thanks for the help.
C. Amick
05-28-2003 09:32:25
 Re: '52 SC Hydraulics contamination in reply to Crispin, 05-28-2003 07:45:22
Milky oil is an indication that it has water in it. I would probably remove the rear plate and clean it. If the line is missing at the pump, you are probably missing the spring and ball that act as a check valve.
