Case 1175 Quad ring problem
Wade
05-30-2003 20:54:19
Have a 1175 Case 451c.i. turbo diesel. About every 2 years I have to replace the quad ring which seals the oil pump to the block. When the ring fails you notice a drop in oil pressure. Put a new one in and it's good for couple years. Has anyone ever had this problem? Or can tell me how to correct it? Doesn't cost too much to fix it just alot of work seems to fail in the busy time of year. Thank you.
john m
05-31-2003 10:22:41
 Re: Case 1175 Quad ring problem in reply to Wade, 05-30-2003 20:54:19
We protect quad ring with thin shim stock while installing oil pump.(slide shim out after pump is in place) Ring is very easy to damage during installation.
Wade
06-01-2003 06:08:57
 Re: Re: Case 1175 Quad ring problem in reply to john m, 05-31-2003 10:22:41
Thank you John M. that is a good idea I will try that tomorrow. The dealers have the quad ring and an o-ring listed for this engine. Do you know if one is better than the other? Thank you again. Wade
john m
06-01-2003 10:49:38
 Re: Re: Re: Case 1175 Quad ring problem in reply to Wade, 06-01-2003 06:08:57
Use sq. o-ring
