1952 Hood Latch -Correct One-
Bart850
06-01-2003 17:25:54
Howdy..was wondering if anyone knows about htis kind of hood latch on a 1952 VAC... I have not seen one like it before and just purchased it. Thanks for the help!
Marc
Richard R. Rhinebold
06-09-2003 16:54:31
 Re: 1952 Hood Latch -Correct One- in reply to Bart850, 06-01-2003 17:25:54
The hood you have is from a "VAC-13" after sn. 5570000 if you need the original part numbers get in touch. Rich
Randy
06-02-2003 15:00:12
I'm pretty sure it is a PBR.
:o)
Randy
Les...fortunate
06-01-2003 19:38:05
It looks exactly like the one on my '52 VAC, serial # 5656680.
Mike from Canada
06-01-2003 18:01:09
Case modified the VAC design after the 1950 model year.
the tin design changed slightly w/ a new hood and latch, different dash panel, quadrant style throttle lever, and the steering gear moved from the torque tube to the front of the tractor.
hope this helps
mike
Jim M
06-01-2003 18:06:29
 Re: Re: 1952 Hood Latch -Correct One- in reply to Mike from Canada, 06-01-2003 18:01:09
I think the change was at serial # 557000 which was mid 1951. Those tractors sheet metal is hard to find. I have one that was grandfathers to restore.
Jason
06-09-2003 18:54:03
 Re: Re: Re: 1952 Hood Latch -Correct One- in reply to Jim M, 06-01-2003 18:06:29
I have a 1951 #5573734 and it took me three years to find the right grill.
