580CK Shuttleshift lacks power
Gary
06-01-2003 19:00:51
We started using a 580CK which had at for sometime. I have changed the shuttleshift fluid twice but the tractor still doesn't move well. Also, it sounds as if the transmission is still engaged when the shuttleshift is in neutral and the gearbox grinds when shifting into gear. The grinding occurs even though the clutch pressure gauge shows 0lbs pressure.
What would be possible soultions? Should I flush the shuttleshift with something and refill again?
I think the tractor is a 67 model. What fluid should I be using? I have used Case TCH but was told this unit should use a 20wt hyd fluid.
Thanks for the help, Gary
Charley In Mo
06-02-2003 08:05:48
 Re: 580CK Shuttleshift lacks power in reply to Gary, 06-01-2003 19:00:51
I've got a machine like yours. Have the same characteristics, kinda hard to shift, makes noise in neutral, etc. Mine has plenty of power and moves well. Have found you have to have throttle at idle to help grinding gears. Sstill does it some even then. I use TCH. Case dealer said to.
