Case 440 hand clutch
Snider Mark
06-06-2003 15:45:53
I use only the main clutch because the hand clutch appears badly worn. It does not slip,but does not disengage well. So I just ignore it. But it would be good to have when snowblowing and bush hogging so I could stop the tractor and keep the PTO running. How big a job is replacing the plates in the hand clutch? Are parts available?
Jim M
06-07-2003 20:37:49
 Re: Case 440 hand clutch in reply to Snider Mark, 06-06-2003 15:45:53
I think you'd have to split the tractor at the front of the 4 speed tranny. Check with your local Case dealer for parts. If they cannot help post on the classifieds and I'm sure someone can help. I've got 3 complete units taken out of parts tractors but not sure of the plates but I would think 1 would be OK
