930/1030 motors
Ohio Case
06-06-2003 18:40:18
Ok I hope that those of you who know more about these motors can clear up a rumor that I've heard. Apparently in the early 70's if you blew a hole in the side of a 401 block and ordered a complete new motor from case it was possible that you might get a 451 motor, like in the 70 series tractors. The would bolt up ok, but you would need to make a hole in the front left flange of the motor for the steering linkage. Now, is this just a pipe dream or is there some truth in this rumor?? And if so does that make the 451 a "stock" motor when pulling it???
Phil Munson
06-08-2003 06:01:24
 Re: 930/1030 motors in reply to Ohio Case, 06-06-2003 18:40:18
If you measure them you will find that the 1030 block is a longer block. They are not the same block.
Jon
06-06-2003 21:22:02
Dont know about that but i took my stock 600 block (377) bought a 1030 sleve set took it too a machine shop boared the block bought used 1030 rods from don L and now I have a 451 with the corect numbers .dynos 105 hp @1900 rpm
Milky2390
06-07-2003 09:45:00
 Re: Re: 930/1030 motors in reply to Jon, 06-06-2003 21:22:02
Jon, I am wondering if you If that is with the stock mannifold, Fuel pump, and heads. Email Me Milky.
Jon
06-07-2003 21:21:25
 Re: Re: Re: 930/1030 motors in reply to Milky2390, 06-07-2003 09:45:00
yes stock manifold,heads,rotary pump with(8mm plunger)and fuel to spare 930 clutch and pp pulls 8000# class in 2nd gear
