Case DO displacement
Frank
06-10-2003 03:47:17
Anybody know the displacement and dimensions of the late DO/DC engine vs. the earlier models? I believe mine to be late 1953 model, and have seen references on here that the engine specs were different on the very late versions. Thanx in advance.
Paul f
06-10-2003 05:53:19
 Re: Case DO displacement in reply to Frank, 06-10-2003 03:47:17
Frank with 3 7/8 (3.825) bore engine displaces (3.825 * 3.14* 5.5stroke * 4) 268 inches
Late models had 4 in bore 276 inches
paul f
Paul f
06-10-2003 06:05:51
 Re: Re: Case DO displacement in reply to Paul f, 06-10-2003 05:53:19
OOPS Little fat fingers on calculator. 3 7/8 bore yield 264 cu inches
This was a test
06-10-2003 15:22:39
 Re: Re: Re: Case DO displacement in reply to Paul f, 06-10-2003 06:05:51
Mea Culpa...It has been awhile since geometry
Area is pie * radius squared... not pie * diameter
Therefor the small bore is 3.825/2 = 1.9125
squared is 3.658
times pie 3.14 = 11.486
times stroke 5.5 = 63.17 cu in per cylinder
times 4 = 252.7
As 4" diameter = radius squared the answer for the later engine was correct (by accident)
How come none of you guys caught me? :-)
Paul f
Bill Hires
06-10-2003 05:41:58
C & D Bore = 4.0", Stroke 5.25" CID = 276.4. Early Bore = 3.875", Stroke 5.25" CID = 260.
Paul f
06-10-2003 05:55:22
 Re: Re: Case DO displacement in reply to Bill Hires, 06-10-2003 05:41:58
Bill My manual shows 5 1/2" stroke, however I have never measured teh engine itself.
Paul f
Bill Hires
06-11-2003 04:51:26
 Re: Re: Re: Case DO displacement in reply to Paul f, 06-10-2003 05:55:22
This information came from the J. I. Case I & T Shop service manual C-201.
