Case 411b-311b
Phil B.
06-10-2003 20:50:25
Have a new toy. Think its a 1958 411b or 311b from the pictures I have looked up. Gas engine. Anyone know if the two tractor have the same engine?? Help need to order service manual.
Jim M
06-11-2003 05:06:00
 Re: Case 411b-311b in reply to Phil B., 06-10-2003 20:50:25
They both should have the 148 engine in them. The 311b would have a dry clutch and the 411B would be a Case-O-Matic drive version
martin in De.
06-11-2003 17:10:41
 Re: Re: Case 411b-311b in reply to Jim M, 06-11-2003 05:06:00
they both have 148 cid engines,but the blocks are different.
Phil B.
06-11-2003 20:46:23
 Re: Re: Re: Case 411b-311b in reply to martin in De., 06-11-2003 17:10:41
Is there a easy way to tell them apart other than the the clutch???
martin in De.
06-12-2003 17:57:17
 Re: Re: Re: Re: Case 411b-311b in reply to Phil B., 06-11-2003 20:46:23
phil,look at the instrument panel,there will be one or two levers. if there is only one on the left side (this is the throttle)then its a 300B. If there is a second lever on the right side(this is for case-o-matic) then its a 400B. also on the 400B there will be two gauges under the instrument panel,one is for case-o-matic oil presssure,the other is for temperature. both of these are fine tractors if you are looking to buy one.
