Case 680 ck backhoe will not run
thundarr blacks
06-11-2003 08:13:36
i recently purchased this gas engine 680 ck 1966 backhoe.can get it to start on starting fluid but wont run when you put your hand over the up draft carberator,it wants to suck in your hand hard,i rebuit the carb and tried a new carb but still wont run,i have a good strong gas supply also and the engine sounds good.can anyone help me with this problem.
john m
06-11-2003 19:43:43
 Re: case 680 ck backhoe will not run in reply to thundarr blackstar, 06-11-2003 08:13:36
I'd tune up the ign, cap,rotor,points/cond,plugs & plug wires with wire cores not carbon. Check static timing. Does coil have a hot,"blue" spark? Are you using fresh gas? Is choke butterfly completely closing?
thundarr blackstar
06-12-2003 08:13:04
 Re: Re: case 680 ck backhoe will not run in reply to john m, 06-11-2003 19:43:43
i also did a tune up with case parts except the coil witch is a new 12 volt coil,and i drained the old gas.i dont know if the wire core is carbon or not.i dont know about the timing,i ordered a manual,when i get it i will check the timing,it will run if you shoot either into the carb.it sounds strong just wont run on carb gas.thanks for your help.thundarr
