930 hydraulic control valve
Chris Reinmann
06-14-2003 11:40:54
I have a 930ck that the remotes will not lift my mower conditioner and the three point won't lift a 1500# bale so I took the contol valve off (under the fuel tank) to find that the casting has a crack on the inside about three inches long. Is it possible to put JB weld on it,get it to hold pressure,and stay on,or will it just break apart? Has anyone made this kind of repair and got it to work? Or do I need to just go find a used valve? I've had Case tractors for a long time (30 years),I read this page on a daily basis and you guys are second to none on Case tractors. Thanks in advance for your help. Thanks, Chris
Jcmarleau
06-14-2003 13:54:51
 Re: 930 hydraulic control valve in reply to Chris Reinmann, 06-14-2003 11:40:54
Maybe i have a use one will check my e mail is jcmarleau@aol.com
