Case 442 Deck Clutch (PTO)
T-Bird
06-17-2003 17:29:22
Have a earlier 70 model 442 lawn tractor. Having problems with blade speed. Mower cut ok for a few yards then blade speed slows down. Could this be a problem with the PTO on the front of the Kohler engine. Where could I find manuals, drawings and parts.
jcmarleau
06-17-2003 19:54:10
 Re: Case 442 Deck Clutch (PTO) in reply to T-Bird, 06-17-2003 17:29:22
i may have manual for your equipment but i need to know which mower you have is it j40 k40 h40 right now you are giving the model of the tractor which is a 442 my e mail is jcmarleau@aol.com
John H-WI
06-17-2003 18:18:20
You might try the Case/Ingersoll board over on the garden tractor forum. Acouple of things to check-is your belt in good shape and tight enough? Not sure of your setup but on all the Case/Ingersolls I owned, 446-448's, the belt tightener was a crank type handle in front. There was a big spring that held the tension and you tightened it till there was a gap in the coils equivilant to the thickness of the spring. Also check the spindles on the mower deck to be sure that there are no bad bearings.
