Case CC 4 on e-bay
Mike from Canad
06-20-2003 07:37:54
wow! this thing's a peach! and starting @ $10!
such a deal!
now all i need is a bigger shop!
feast yer eyes!
mike
Les...fortunate
06-20-2003 11:35:46
 Re: Case CC 4 on e-bay in reply to Mike from Canada, 06-20-2003 07:37:54
Must be a '38 ain't it?
C. Amick
06-20-2003 08:11:18
OK, if this is a "CC" then doesn't that mean it is a tractor that is set up to cultivate? Shouldn't it have an adjustable width front axle?
CASEPOWER
06-20-2003 09:44:49
 Re: Re: Case CC 4 on e-bay in reply to C. Amick, 06-20-2003 08:11:18
No, the CC-4 was non- adjustable, but case sold many with both wide and narrow front and the farmer could change the front if he wanted. A lot of the early CC's had problems with the front casting breaking and were changed to wide fronts. The first casting weighed 50 pounds then they went to a 100 pounder then to the 150 pounder that they used through the D series also. The tag on the auction tractor is a repro so it is hard to say what it really is. It also has a D series head and a gas manifold. Never know it could be one of them 7 CH series made. I can't seem to tell them apart from the pictures.
C. Amick
06-20-2003 10:07:10
 Re: Re: Re: Case CC 4 on e-bay in reply to CASEPOWER, 06-20-2003 09:44:49
Well. I still don't see how anyone could cultivate with this tractor without being able to adjust the front axle width. Where did the front cultivators mount?
John H-WI
06-20-2003 16:02:21
 Re: Re: Re: Re: Case CC 4 on e-bay in reply to C. Amick, 06-20-2003 10:07:10
This one wasn't used for cultivting. It was basically a wide front tractor same as the C. Big difference between the C and this one was that the CC-4 has the bigger tires and individual brakes on each wheel same as CC. Much nicer to drive in the fields than the C with that *(&**%$% hand brake (speaking from farming experiences).
