Case vai
G FROM MD
06-21-2003 18:38:51
I have just got what i think is a vai. What years did they produce them. It has 24 inch back tires, non adj. wide front, 4 sp. trans.,16 inch frt. tires and side mounted sickle bar.
G FROM MD
06-22-2003 18:35:11
 Re: Case vai in reply to G FROM MD, 06-21-2003 18:38:51
Yes it has a overhead valve engine, heavy thick front axle.
Mike from Canada
06-23-2003 00:41:18
 Re: Re: Case vai in reply to G FROM MD, 06-22-2003 18:35:11
VAIs were made throughout the VA production timeline (1942-1955) and a total of 15,031 units in that time.
they came in the traditional flambeau red, dark military green, or industrial (old caterpillar) yellow.
some models were equipped w/ a high speed travel 4th gear (20 mph) compared to the standard 4th gear (12-15 mph) on regular VA series tractors.
they came w/ sickle bar mowers, mainly on versions sold to hwy. departments to cut ditches and medians. but ive seen a military version w/ a mower on it in a book once.
hope this helps!
mike
Alberta Mike
06-22-2003 15:53:03
What makes you think that it is a VA? Any tin tag on the dash with a serial number? If so it should start "VAI" then the serial number. I think the Industrial versions had a very heavy front axle. Is it an overhead valve engine or a flathead? The model V's looked very much like the VA's and they also made the industrial version and had 24" rear rubber on the standard wide front models. The V series used the flathead Continental engine.
wheat straw
06-22-2003 12:01:09
G,
They were made throughout production. about 300 in 42 and just 5 or 6 in 56. A VAI was the last of the VA series made. there biggest production year I think was 48. There was just over 15,000 made.
wheat straw
