Case 930 trouble starting
Garry
06-27-2003 09:46:36
My Case 930 arrived a couple days ago. I am working on getting the batteries charged up but I was wandering if it could be pulled started without causing any damage. The engine is not locked up. The ignition key is also missing. I am using a mail box key but it doesn't fit very well. Any suggustions on a key.
Key
06-27-2003 10:41:39
 Re: Case 930 trouble starting in reply to Garry, 06-27-2003 09:46:36
For a key, go to any Case dealer..... Like he says, not needed to run, but will sure run the battery down when you forget to shut it off. Been there, done that----with a 24 volt 1200.
Kevin
06-27-2003 10:14:45
We have a 930 with bad batteries. It has the six speed transmission with a hand clutch. We put it in 5th gear, and give it a pull with our 1070. After it begins moving, we apply the clutch and it fires up right away and runs great. We have an ignition key, but it doesn't matter if it is on or not. Hope this helps.
