930 clutch problem
bob
06-27-2003 10:53:41
This is a 930 draft o matic. with a foot clutch. Was cutting hay with it the other day when this happen. WHen you push the clutch in the clutch does not disengage. Took the inspection plate off the side to see whats up. everything appears to be working fine when clutch is depressed the pressure plate moves a good 1/4 inch. Wehad the problem of this tractors clutch pedal sticking foward. rust got to the pivot point on the shaft. Would this have caused the throw out bearing to fail some way. Could the fingers be some how locked in to the clutch.
Like i said its been a bad week look down at the 1030 post below. Our cases are dieing fast on use.
bob
06-27-2003 20:13:22
 Re: 930 clutch problem in reply to bob, 06-27-2003 10:53:41
Done more checking through the inspection hole on the side this afternoon. Looks to be one finger bent in. SO the throw out bearing is only releaseing 2 of the 3 fingers. How it got bent is beyond me. Will find out soon though when i spilt it.
Jim Handke
06-27-2003 18:56:50
We ran into the same problem on a 1175. The throw out bearing carrier was bad. When you push the clutch in, the tube the bearing slides on would move with the bearing. It would push against the clutch, holding it against the flywheel. Also ran into this problem on my cousin's 3010.
