630 Caseomatic PTO
GERALD
04-23-1999 21:02:38
The PTO shaft on my 630 Caseomatic doesn't disengage completely. It 'free-wheels' with enough force to spin a 6' bushhog when its raised up out of the grass. Also what is the correct oil for the rear end? Any ideas
Shaun In Wisconsin
04-24-1999 05:36:33
 Re: 630 Caseomatic PTO in reply to GERALD, 04-23-1999 21:02:38
The 630’s demise came early thus it never got the independent PTO; the early models had what most would consider a POOR design. I was informed from my CASE dealer that when these particular PTO’s were new they would sometimes spin. If you push down on the lever with your right foot it may stop.
Roger also told me that they have rebuilt these and most often they would still turn.
Depending on what you use your machine for and what type of conditions you’re in will determine what oil you’ll use Contact your local CASE IH dealer and go with what they are using
Gerald
04-27-1999 20:22:35
 Re: Re: 630 Caseomatic PTO in reply to Shaun In Wisconsin, 04-24-1999 05:36:33
Shaun
Thanks for your help, I was afraid it might be something like that. I was just hoping for some easy adjustment or quick fix.
