1175 Vs. 1030
Ohio Case
06-28-2003 13:04:07
After shopping for an 1175 to turn into a hot farm puller I realize that they are a bit more expensive than I had originally expected, which got me thinking about the 1030's. Other than the planitaries in the wheels of the 1175 is there any real advantage to it over the 1030? Local club rules are 4000 rpm max, 466 max cid, 3 in 3 out turbo, single port water injection 10,000 lbs. Will a 451 bolt into a 1030 tranny if not how many modifications would there need to be?
Thanks
toolman
06-29-2003 13:06:41
 Re: 1175 Vs. 1030 in reply to Ohio Case, 06-28-2003 13:04:07
dump the 451 and bolt in a 504 and have some real fum. it is direct bolt in just drill the hole in block for the steering shaft.
Ohio Case
06-29-2003 20:47:41
 Re: Re: 1175 Vs. 1030 in reply to toolman, 06-29-2003 13:06:41
As much fun as it would be to do that tool man, if the "good ole boys" ( red and green ones) even suspected that I was over cubed they would pump the cylinder in blink of an eye, count the injectors on their fingers and toes and would figure out I was a little big. Local class you can't be over 466. But it sure would be fun!!!!! !
Jim M
06-28-2003 17:50:18
I have read that the 1030s had transmission problems. The book said that the tranny had been strecthed beyond the HP it could stand with the 451 motor.
darBy
06-28-2003 15:53:23
The block will fit up to the clutch with no problem but the front of the engine is a different story. Unless you use an early 451B (maybe out of a 1070) there is no hole in the block for the steering shaft on the left side. The 70 series did not have a mounting for the power steering pump. There are several other minor differences but putting a 70 series engine in a 30 series tractor has been done many times. Good luck.
rick
06-28-2003 15:22:32
the 451 should bolt right in since the 1030 already has a 451.
