530 steering problems??? (help) Please
Jeff
06-28-2003 19:10:22
Help Me Please,I have a 1964 Case Construction King Forklift. i've been working on it for about a year now. when I parked her the steering worked fine, but now that I have her running again the power steering doesn't hardly work??? do you have to bleed it or ??? the pump is under the alternator. None of my farm tractors have this type of pump? Thanks Jeff.
Dennis/Ohio
06-28-2003 21:03:25
 Re: 530 steering problems??? (help) Please in reply to Jeff, 06-28-2003 19:10:22
Hi, I believe you have a hydra-static steering system. It will bleed the air when you turn from stop to stop. Wondering if its time for a filter change (filter should be in the reservoir) and fresh oil? Dennis....
Jeff
06-29-2003 06:02:30
 Re: Re: 530 steering problems??? (help) Please in reply to Dennis/Ohio, 06-28-2003 21:03:25
Hi Dennis,yes it does have hydra-static steering. where is the reservoir and filter for the pump??? is it in with the dipstick??? Thank You Jeff.
Dennis/Ohio
06-30-2003 18:59:42
 Re: Re: Re: 530 steering problems??? (help) Please in reply to Jeff, 06-29-2003 06:02:30
Yes, the reservoir & dipstick is held on with a nut & washer. Element part # A30834 (probably will cross over to a newer part number
