Case 1030 clutch
Tom s
06-30-2003 20:46:59
Yesterday when I was baling hay and would stop to unload a bale the tractor would keep wounting to moving foword with the clutch pushed in. It didn't happen evertime but did get worse as the day went on. Should I worry about it right now or can it wait until winter
jcmarleau
07-01-2003 08:04:15
 Re: case 1030 clutch in reply to Tom s, 06-30-2003 20:46:59
I have usec items if needed my e mail is jcmarleau@aol.com
Jim Handke
07-01-2003 05:07:09
We have run into this problem twice. The throwout bearing carrier was the problem. The tube that the bearing slides on comes loose from the casting. When you push the clutch in, the throwout bearing slides the tube into the clutch hub. There's just enough drag on the flywheel to keep the clutch turning. If this is your problem, your not going to ruin anything else. Just poses a safety problem if you don't stop when you need to.
Tom s
07-01-2003 16:46:01
 Re: Re: case 1030 clutch in reply to Jim Handke, 07-01-2003 05:07:09
Thanks for the info Jim. So that means I will be spliting the tractor in half and changing some parts this winter.
