Case 580 b tech help
james
04-25-1999 10:08:04
I have a case 580 b with a power shuttle 4 speed trans i will not come out of forward if you run the machine at an idle you can shift through 4 gears without using the clutch and the machine goes forward correctly but when you step on the clutch when it is in gear it does nothing except keep going forward when you shift the shuttle to neutral or reverse this doesnt do anything either It only goes forward and the clutch wont stop it ANYONE WITH EXPIERIENCE WITH THIS PLEASE RESPOND
