52 Case VAS
ACEd
07-01-2003 20:24:04
Need info on where to get motor parts - pistons, rings, sleves for a Case VAS - understand same as VAC - motor starts either 72C or 72G can't read.
Also need rear fenders for VAS
Larry Noller
07-02-2003 21:36:42
 Re: 52 Case VAS in reply to ACEd, 07-01-2003 20:24:04
If you will e-mail me I can give you a number where you can get parts for a lot less than you will pay at the dealer. I just got done going thru the engine in my 52 VAC.
Mike from Canada
07-02-2003 01:40:21
most parts are available @ the dealer for the engine.
body panels however...
you may keep an eye out on e-bay. VAI fenders are the same size. VAC, VAO, VAH, VA fenders may be too large but will fit too if you like the protection.
good luck!
mike
martin in De.
07-02-2003 16:40:51
 Re: Re: 52 Case VAS in reply to Mike from Canada, 07-02-2003 01:40:21
Mike, I donot believe any of the fenders from the other VA series tractors will fit the VAS.
Mike from Canada
07-03-2003 02:06:57
 Re: Re: Re: 52 Case VAS in reply to martin in De., 07-02-2003 16:40:51
there i go making assumptions again.
i just figured since both the VAI and VAS came w/ 24" tires they would match up. my parts manual doesnt even give a listing for VAS tin.
sorry
mike
mj
07-03-2003 13:47:44
 Re: Re: Re: Re: 52 Case VAS in reply to Mike from Canada, 07-03-2003 02:06:57
I believe that VAS fenders are mounted as part of the floorboard assembly while on the other models in the VA series they mount to the rear axle directly. :-)
