Case 440 H, identify
Robert
07-02-2003 12:21:12
Can someone help me identify what I have and where to get info. It is a Case 440 H on the name plate. Farm tractor, 4 speed, H & L lever (on the right), Forward and Reverse lever (on the left). Thanks in advance, Robert
Dennis/Ohio
07-03-2003 20:02:01
 Re: Case 440 H, identify in reply to Robert, 07-02-2003 12:21:12
Should be a gas utility tractor. Sits lower to the ground than a 541 general purpose tractor. Has a I-beam solid front axle, 148 cu in engine. Must be a dual-range with shuttle (dry clutch). Not knowing its a Utility tractor would probably cause problems at the dealer when looking for parts. As far as I know the H is for highway gear. They go about 20 mph in highest speed. Big change in mph between 3rd & 4th gear. Dennis.....
jcmarleau
07-02-2003 17:15:32
What do you mean you have a Case tractor with a gaz engine waht do you want to know exactly. my e mail is jcmarleau@aol.com
Les...fortunate
07-02-2003 19:30:14
 Re: Re: Case 440 H, identify in reply to jcmarleau , 07-02-2003 17:15:32
Monsieur Marleau, would you by any chance be in La Belle Province? If so, where?
