430 case
wade
07-03-2003 04:48:11
We have a 430 case that sounds like it has a bag or marbles in the tranny at certain speeds. It also jumps out of high range at times. Anyone know what this could possibly be?
Roger
07-15-2003 21:32:41
 Re: 430 case in reply to wade, 07-03-2003 04:48:11
Wade,
Some noise from the Case triple range is normal at certain speeds. There should be little or no noise from the triple range when it's in "direct". Check the tension on the high range detent spring in the triple range cover. If the tension is too low, it will likely jump out of high range.
Jim Handke
07-03-2003 05:19:19
It sounds like a bad bearing on the transmission shaft. The play in the bearing lets the shaft move and the pressure on the gears makes them back out of gear.
