680B backhoe
Sammy
07-05-2003 15:14:39
I went to look at a 680B hoe today. Engine seems to run good and hydraulics work ok. The guy selling this machine says after it warmes up the shuttle wont pull in 4th forward but pulls fine in 4th reverse. He runs down the road backwards to move to his other farm. any ideas what could be wrong? the serial no. is 9105803 can any one tell the year by this number? thanks for any info Sammy
jimks
07-05-2003 19:58:33
 Re: 680B backhoe in reply to Sammy, 07-05-2003 15:14:39
the foreward clutch in the shuttle is going out... big money and lotsa work. The foreward clutch usually goes first for whatever reason... I drove a lot of 580's into the shop backward.
Sammy
07-05-2003 22:10:40
 Re: Re: 680B backhoe in reply to jimks, 07-05-2003 19:58:33
Thanks for the reply. will the tractor need to be split to make this repair? I guess there is a clutch pack that wears out? This is a dealer idem that can't be found used? Any idea what a machine like this in fairly good shape would be worth for farm type use? thanks for the info Sammy
