Can't remove hyd. pump on 210B
Mike Johnston
07-05-2003 15:16:51
Trying to remove the adapter housing / hydraulic pump from the torque tube on a 210B. The housing can be lifted about 1/4" off the tube, then it binds up and will not move any further. The bind appears to be near the front of the housing. I removed the side plate off the torque tube to try to find the bind. Nothing appears out of the ordinary. The pickup tube seems to have clearance, and the gears look fine. Any ideas on what it could be binding on?
Thanks in advance for any replys.
Mike Johnston
Jim M
07-05-2003 20:49:48
 Re: Can't remove hyd. pump on 210B in reply to Mike Johnston, 07-05-2003 15:16:51
I have been parting out a couple with that pump on it lately and have found some bolts that have to be removed while lifting up on the pump cover because there is not enough room for the bolt to be taken completely out without further disassembly.
