CASE 400 block
Ken C.
07-05-2003 21:41:57
Are there any other tractor engines that will interchange in a 400 diesel, and what size cid is this engine. Have got a cracked block now and was wondering if anything will swap out. Thanks for any info, Ken.
Kennyp
07-06-2003 05:35:48
 Re: CASE 400 block in reply to Ken C., 07-05-2003 21:41:57
If gas would be an option, you might keep your eyes open for a Case combine. Mine is an 830 gas engine.
Dale in Tx
07-05-2003 22:00:50
Ken The block in the 700,730,.830,will all inter change might haveto modify the steering shaft notch in frount,If it is an early 400 diesel is 251 cid,if a400 super is 267,the 700 diesel is 267 730 267,283, the 830 is283,301. Dale in Tx.
Ken C.
07-06-2003 15:46:04
 Re: Re: CASE 400 block in reply to Dale in Tx, 07-05-2003 22:00:50
Thanks for the info, i did'nt know i had that many options. The 830 would make a good bit more power i would think. Thanks again, Ken.
