880 hydraulics help needed
rhudson
07-07-2003 13:52:04
I guess Elmer gets tired of messing with people like me. 880 implematic, lift arms will not go up under load. i purchased it that way. the pump looks new. the valves that are located at the pump did not look as in my manual. but i took them apart so long ago i can't remember what was different. i have high flow from the pump but very low pressure. could it be the valve that is over the right hand axle? (traction valve?) or should i take the rear off and investigate the pump valves again? Thanks for any help. its been my experience that if it were not for hydraulic problems, david browns would have no problems at all.
