311 Hyd pump
SheldonMT
07-09-2003 21:20:10
What is the gpm and the operating pressure of the Hyd. pump on a 311? Also is it possibleto put a second pump on the opposite side as I was told? Thanks Sheldon
Joe (Wa)
07-09-2003 21:52:40
 Re: 311 Hyd pump in reply to SheldonMT, 07-09-2003 21:20:10
The pump in the torque tube is rated 9 gpm, 1200 -1300 psi @ 1750 engine rpm. What do you mean by second pump on opposite side? 300 series has stackable control units w/ interlock blocks. Normally lower unit drives single-acting cylinders (eagle hitch, etc) from right side and upper unit is used for single or double acting applications off the left side. Joe
