Case 1070 AC Belt
Jeremy Roggasch
07-12-2003 13:56:04
I have an early model yellow Case 1070. I am having trouble getting the AC belt to stay on . It has a really narrow belt running from the crankshaft up to the compressor on top of the head. The belt seems to have excessive vibration. I have just put on a new compressor and new belt and new filter dryer. The previous owner of this tractor had the same problem. I would appreciate any advice anyone can give on this. Thankyou
Jim Handke
07-13-2003 08:41:24
 Re: Case 1070 AC Belt in reply to Jeremy Roggasch, 07-12-2003 13:56:04
Dad's 970 is equipped with that same setup. The groove in the bottom pulley isn't wide enough, and the belt would run(jump?) off of it. He took it off and chucked in his turning lathe and made the groove a little deeper and wider. Used a new belt as a guage. Hasn't had a bit of trouble with it since, more than ten years later.
Paul f
07-12-2003 15:14:59
Jeremy: Can't really help much on your A/C. All my equipment relies on basic A/c, for more A/C... drive the tractor faster into the wind...on the truck push the windshield out farther :-)
Paul f
