1945 VAC 6to12 volt conversion
Da
07-13-2003 20:15:35
can any one tell me if this is positive ground and how can i make it negitive groung
GeoMO
07-15-2003 07:46:24
 Re: 1945 VAC 6to12 volt conversion in reply to David DePrie, 07-13-2003 20:15:35
I put a GM alternator on my VAC.
I had to change the switch when I did.
It would never start (have had sense 1959) with a 6 volt battery. I do not remember anything about CCR back then so the batteries may have not been as good, but were new.
John Saeli
07-14-2003 19:40:50
Hey David; I believe it is positive ground. 6V is very satisfactory if: 1. You have a good battery, 600CCA @ 0 or better. 2. The tractor is equipped with size 2/0 battery cable with good clean connections.
