1953 SC weight
Wolverine
07-18-2003 17:32:12
What does a 53 SC weigh? Is there a site that lists specs on different cases?
jal-SD
07-21-2003 06:40:30
 Re: 1953 SC weight in reply to Wolverine, 07-18-2003 17:32:12
Took my '54 SC (foot clutch, Eagle Hitch, LPTO) to a tractor pull on June 8. It does not have fluid or weights, nor does it have the weight under the radiator. I was suprised at how heavy it was-weighed in at 5,190 w/my fat bu## (180 lbs) on the seat. No way could I get it under 4,500 to pull in the class that it should be in. Had to pull w/G JD's, SM's & 460's & 560's Needless to say, I didn't win anything. (My $0.02 worth. jal-SD)
L.Lamp
07-21-2003 18:39:34
 Re: Re: 1953 SC weight in reply to jal-SD, 07-21-2003 06:40:30
I have a 54 SC like yours and weighed it at a local elevator without me on it. It weighed 4905 with the weight under the radiator and one 150 on each rear wheel. Still too heavy for 4500 class but not as heavy as you. It had all the things a 54 SC should have. Somebody must be pulling your chain!
Mike Schotte
07-19-2003 05:22:47
This should get you in the ballpark...
-Schotte
