1200DB blown headgasket
pat downing
05-01-1999 02:57:06
i blew a headgasket on my 1200DB putting about 1 gal anti-freeze in the oil sump the bottom end seems ok no knocking or rapping question is how to get the watery mess out other then change the oil 4-5X or drop the pan
David Davis
05-01-1999 13:23:59
 Re: 1200DB blown headgasket in reply to pat downing, 05-01-1999 02:57:06
After it sets several days you can losen the drain plug till it starts to seep,the antifreze and water will be under the oil. Do this once a year to the trans and rear boxes to let the condensation out.Dave
Elmer
05-01-1999 07:22:57
Drain the oil and leave the plug out while replacing the head gasket. Any moisture left will go to the bottom of the pan when you get it running again. Won't do any harm. It will come out at next drain interval.
