'66 930 Hydraulic trouble
Greywolf
07-25-2003 09:09:13
After 4 trips to the dealer for repairs, I've given up on them. First the 3 point didn't lift, after 2 trips for that it works fine, but now, the remotes load up on their own.
The left side of the remotes, both of them, at idle will generate 650# pressure without moving control levers. 1500 RPM will generate around 1250# of pressure for both. Right side remotes have static pressure with the control levers in neautral. The levers are in neutral and stay in neutral after moving. After relieving pressure via the control handle, BOTH remotes will load back up. Dealer says it is impossible for both to load simultaniously. So I guess I have a "special tractor" here...LOL.
Anyone give me any ideas on where to start teardown??? What to look for? Was thinking of the left hand remote block and checking for seating of the check valves, but with both remotes having the same symptoms, I'm thinking that might be mute.
