Case 530 (caseomatic)low clutch pressure
Paul Keeping
05-03-1999 13:44:04
I've recently bought this machine and I'm looking for some insight. The clutch pressure indicator reads low and it sits on the stall for quite a while when the clutch pedal is released. The operators manual says never operate under load until the cause of the low pressure is determined.
Does anyone have any suggestions for determining the cause. I've changed the fluid and put in a filter(there wasn't one). It seemed better for a little bit. Would a more viscous fluid help? I'm using TCH.
Anyone have the service manual? I'd like to find out what it says about low clutch pressure.
Anyhow thanks, Paul
Paul F. Johnson
05-07-1999 08:46:01
 Re: Case 530 (caseomatic)low clutch pressure in reply to Paul Keeping, 05-03-1999 13:44:04
Paul,
I would fix the slow return to high pressure upon releasing the clutch before worrying about the low pressure reading. I think your problem is a sticking/malajusted spool on the Case-O-Matic control valves. The manual (both the factory and the IT version) go through a very thorough troubleshooting procedure: be sure to adjust the linkages to the two spools properly, most problems are solved by linkage adjustment; a $8 pressure gage and a few fittings provide better pressure readings than the go-nogo gage in the panal (160psi at filter, 30 psi clutch in, 110-130 psi clutch out---these numbers are from memory as I don't have my manuals handy at the moment). A spacer can be used to compensate for a weak spool valve spring.
The good news is that the parts are available and not expensive. The bad news is finding out exactly what's wrong is tedious, and even when all works well, gears grind, gnash, and generally sound terrible. Higher viscosity oil makes gear grinding worse.
Let me know if specific details from the Case 430-530 manual would be helpful, and I'll dig out my set (which, by the way, I might sell if I can recover my costs).
Regards,
-Paul
