1951 Case VAC for sale
Bill Woods
08-04-2003 05:41:50
I have a 51 case with a front bucket assy run off a front pump and an eagle hitch for sale for parts. Last weekend while brush hogging the oil pressure spiked high and then the motor quit. The crank can be still turned, barely, so she's not quite seized up. Tires are new and calcium loaded, everything works on it except the engine. Transmission reverse gear has a piece of a tooth missing but has worked that way for years. I have had it for about 15 years and cannot afford to fix it. While trying to restart it the starter spring broke, so that needs replacement. When I bought it the head was freshly rebuilt as well as the carb. The exhaust manifold is new too. Located in upstate New York near Penn Yann. Someone with the time, patience, money and experience will have a good unit or a lot of good parts.
mj
08-04-2003 16:29:04
 Re: 1951 Case VAC for sale in reply to Bill Woods, 08-04-2003 05:41:50
Why don't you drop the oil pan, main and rod caps and see how the crankshaft looks? Might be a bit of emery cloth and some new bearing inserts will put it right again. :-)
Mike from Canada
08-04-2003 12:24:34
thats too bad about your poor tractor. sounds like you put a lot into it only to be repayed w/ problems. if your willing to bring it to toronto, ill make sure it gets a good home.
what a heartbreaking story. sorry for your loss.
(sniffle)
mike
tom
08-04-2003 06:32:17
how much do you want for it?
bill woods
08-05-2003 13:24:33
 Re: Re: 1951 Case VAC for sale in reply to tom, 08-04-2003 06:32:17
Not sure on the price. I paid about 2000 for it years ago and have put a few bucks into it. I may just eBay it and see what happens. Was hoping to see some offers thru this site first.
mj
08-05-2003 14:34:13
 Re: Re: Re: 1951 Case VAC for sale in reply to bill woods, 08-05-2003 13:24:33
How about posting it in the photo ads so we can see what it looks like....or use the YTmag auction with a picture....how bad was this seizure anyway??
