Stabilizer arms for a 995
Magnum65
08-12-2003 13:09:16
I need 2 stabilizer arms for my 995 Case, 1977 model. I also need 2 each for my 1976 1210. Any help would be appreciated
Elmer
08-12-2003 14:59:09
 Re: Stabilizer arms for a 995 in reply to Magnum65, 08-12-2003 13:09:16
I just got a jobber stablizer in to see what kind of quality it is. It looks good but i need a different anchor bracket to go on the final drive. Have to sort this out. Do you have the pins and anchor brackets or do you have nothing? Get back to me at elandman@wightman.ca
jim
08-13-2003 06:11:59
 Re: Re: Stabilizer arms for a 995 in reply to Elmer, 08-12-2003 14:59:09
Elmer - Just to let you know , that sway bar set up I emailed you about works real well. Total cost less than $60. 20" cat1 top link , 1/2"plate cut and holes bored at machine shop, (2)6" fine thread 3/4" grade 8 bolts along with 2 standard nuts , 1 jam nut and 1 lock nut. Don't have access to a camera to send a picture.
Elmer
08-14-2003 04:34:14
 Re: Re: Re: Stabilizer arms for a 995 in reply to jim, 08-13-2003 06:11:59
See you at the world plowing match.
Magnum65
08-12-2003 19:06:35
Elmer;
I have the anchor brackets. Need the arms. Also, took delivery of the tractor tonight and the lift won't lower. Possible causes? Let me know.
Thanks
Barry
08-17-2003 19:53:07
 Re: Re: Re: Stabilizer arms for a 995 in reply to Magnum65, 08-12-2003 19:06:35
I have got an extra set of stabalizer bars for my DB990A. I don't know if they are the same ones for the DB995. I would be willing to sell them, just let me know. I could give you the length if you want, but it may take me a few days. Leave me an email if interested.
Barry R.
Magnum65
08-19-2003 09:37:02
 Re: Re: Re: Re: Stabilizer arms for a 995 in reply to Barry, 08-17-2003 19:53:07
Please send me the measurements and I'll see if they will work. Quick question: are the the round rod type with the swivel ends?
Thanks.
Barry R
08-19-2003 21:00:43
 Re: Re: Re: Re: Re: Stabilizer arms for a 995 in reply to Magnum65, 08-19-2003 09:37:02
The stabilizer arms are original equipment for DB's, they even still have some black paint on them. Solid Round rod type with swivel eye ends.
Send me an email at the address below so I can email you direct, it may still take a few days before I get out to the farm to get the measurements.
'reneaufamilyof3@insightbb.com'
