1948 Case
David
08-14-2003 08:57:41
third party image
I was given a 1948 VAC Case. What manuals do I need to get started and where might I pick them up. It was last used about 2 years ago. But one big question to get me started -- how do I check the oil? Sorry but I am a city boy, just starting to restore this tractor.
Ken Tabor
08-14-2003 11:55:08
 Re: 1948 Case in reply to David, 08-14-2003 08:57:41
It may not apply, but I have a 1950 model D. The oil level on the D is checked at a plug on the side of the oil pan. There are actually two plugs, a hi and a low level. (1/2 in pipe threaded plug)
C. Amick
08-14-2003 09:21:28
There should be a dipstick just to the left and below the carburetor on the side of the engine block. I can almost see it in the photo.
David
08-16-2003 16:40:05
 Re: Re: 1948 Case in reply to C. Amick, 08-14-2003 09:21:28
Good News Bad News, Oil and battery changed! Turns over but does not start. It's like it is not "firing". I ordered a manual --- til then any suggestions?
C. Amick
08-18-2003 05:51:15
 Re: Re: Re: 1948 Case in reply to David, 08-16-2003 16:40:05
Do you have voltage coming to the distributor and coil when the switch is on? If so, you might try replacing the points and condenser. NAPA auto parts should have them. You may need to bring the old ones in so they can match them up. If the tractor has been sitting for a long time the coil could have gone dead. NAPA should have the coil as well.
David
08-15-2003 06:02:31
Yes, you were correct. I was looking for something along the lines of a dipstick handle. This one looks more like a "knob".
C. Amick
08-15-2003 06:33:43
 Re: Re: Re: 1948 Case in reply to David, 08-15-2003 06:02:31
It should have a handle on it, perhaps it is broken off. Your local auto parts store should be able to order the oil filter. There is a metal stem that slides up into the filter. Make sure it is attached to the housing that the filter screws in to.
David
08-14-2003 12:10:08
Thanks for the replies, I will check it this eveining. I read a previous post regarding oil, is 15w40 ok for this one too? I am in Southern Indiana (Tell City) area.
C. Amick
08-14-2003 12:21:32
 Re: Re: Re: 1948 Case in reply to David, 08-14-2003 12:10:08
Using 15w40 is OK. I use the 30W heavy duty in all my antique tractors year round. It should run with around 15 psi of oil pressure, if the engine is not worn out.
