1949 CASE VAC
Chris Gieseke
08-15-2003 05:31:55
I have a 1949 CASE VAC. When I removed the oil pan I found pieaces of a brass ring. I am thinking it came from the governor. Is this correct? Do I need to replace it before running it? How will this affect its preformance?
Bill Hires
08-15-2003 08:38:04
 Re: 1949 CASE VAC in reply to Chris Gieseke, 08-15-2003 05:31:55
End play of the crankshaft is contolled by two brass thrust washers between the front main and thrust plate at the crankshaft gear.
C. Amick
08-15-2003 05:54:00
Are you sure it was inside the oil pan and it's not the seal ring from the oil drain plug?
