1940s Case without serial tag
James
08-18-2003 15:25:56
I have been in the antique tractor hobby for about 3 years but have never purchased one. Now I have the opportunity to purchase one but it does not have the serial number plate. Should I still be interested in this tractor? What is the downside of not having this plate? Does it matter? So of you experienced guys help me out. Also if these tractors were made for almost 10 years is there any way to determine what year it actually is without the serial plate? Thanks
James Dalton
John H-WI
08-18-2003 16:14:45
 Re: 1940s Case without serial tag in reply to James, 08-18-2003 15:25:56
You haven't give much info on the tractor, ie color may give a clue. You can also check on the left side of the engine block towards the rear where it bolts to the transmission housing. The serial and model are stamped there for some models. Also you may go to the tractor photos and do a search on Case. You should be able to find one that looks like the one you are looking at.
