1370 problems
Ralph
08-25-2003 18:17:51
Was plowing and started getting a vibration coming from the transmission. Now when I push in the clutch I get a grinding sound coming from the transmission. When the clutch is released the forward gears there is no sound, in reverse makes the same sounds when the clutch is engaged. Does anyone have any ideas?
Jim Handke
08-28-2003 07:10:53
 Re: 1370 problems in reply to Ralph, 08-25-2003 18:17:51
A friend's 2670 did that. The center bearing in the planetery went bad. Cost him $4000 for the dealer to fix it.
john Saeli
08-26-2003 17:41:56
Ralph; I was expecting someone with more knowledge about this than me to answer. But, they probably didn't want to be the bearer of bad news. Here it is. Very expensive. Sounds like the reverse planetary unit chewed up.
dale
08-26-2003 22:14:46
 Re: Re: 1370 problems in reply to john Saeli, 08-26-2003 17:41:56
I bought one near you [John ] several years ago ,in Lodi, N Y . The guy did n't have the power shift presures checked and adjusted to shift right. It Trashed every thing in there, [hope you have better luck than this guy did] I bought it for parts[ was going to fix it even bought a whole rear end, with long axals,and then sold the Engine]I hope you stopped in time to save some of it!
Ralph
08-26-2003 17:52:56
Thanks John for the info. I am in the process of tearing it down. Will know by tomorrow.
