1190 steering prob
scott
08-28-2003 09:25:55
I have a problem with power steering on a Case 1190 that has me baffled. The tractor will pump all of the PSF out of the overflow outlet in the reservoir. It looks to me that simple gravity would prevent it. I put a new steering valve on it and that didn’t help. So my question is; is there a bypass valve in the pump stuck open or is the cly bad? Any thoughts?
Elmer
08-28-2003 15:08:16
 Re: 1190 steering prob in reply to scott, 08-28-2003 09:25:55
The seal on the shaft of the pump could be allowing air into the system and foaming the oil. That will make it expand and leak out the overflow.
