1941 SC questions
Josh
09-01-2003 09:28:15
I have a 1941 Case SC tractor that I would like to restore. I have several questions about it. Is there a good quality reproduction 6 spoke steering wheel available? How about quality reproduction guages? The headlights (one on each fender) are in rough condition. Are reprodcutions available or should i look for better used ones? It also has a motor lift. What type of attachments were produced for the motor lift? I am sure cultivators would be one but how about others? Are any of these attachements still around? It needs rings and rod bearings, where should i look for these, I understand they can be hard to find. Thanks for any help!
dctom
09-01-2003 09:52:37
 Re: 1941 SC questions in reply to Josh, 09-01-2003 09:28:15
Josh< yes repo gages aviliable from antique gages 302-875-5255, minkota in minn. can recover the 6 spoke wheel, lenses are available for thoes big lights, bearings can be a prob, they are inserts maybe auto store can help you there if not call don L at 507-433-0073 all mounted epuipment will work with motor lift, hope this helps DCtom
