1410 David Brown ? for Elmer
cjh
09-01-2003 17:02:58
Hi Elmer,
I have removed the pistons and had the head rebuilt on my 1410. My question is how do I remove the antifreeze from the block. I have drained the radiator but I cannot find a drain plug for the block.
Also since the motor is torn down do u reccomend the bearings and seals on the crank be replaced?
Will we have to split the tractor to replace the crank bearings???
Thanks for the info
cjh
