1946 Case VA oil seal replacement
Josh de Zwart
09-01-2003 18:46:42
Could anyone advise me if I can replace the front oil seal of my 1946 Case VA without removing the whole engine???
Thanks in advance,
Josh de Zwart, Calgary
C. Amick
09-02-2003 09:23:15
 Re: 1946 Case VA oil seal replacement in reply to Josh de Zwart, 09-01-2003 18:46:42
I think you will have to remove the front timing cover to get to the seal out. The motor pulley will have to come off to remove the timing cover. You are probably looking at having to unbolt the front tractor housing and pull it away from the engine to get to everything. I could be wrong. I think you have a Continental engine and I've never worked on one of those.
