1945 VAC stuck in 4th gear
Gary Cash
09-02-2003 14:34:17
I originally posted this without showing the model in the Subject title. My 1945 Case VAC is stuck in 4th gear. This happened after driving the tractor around my property and down a paved road for about 1/4 mile in 4th gear. The gear lever position is in neutral. I can start and operate the tractor in 4th gear by depressing the clutch but as soon as I try to shift it to another gear, it will only go into what appears to be the reverse gate. In the reverse gate the tranny locks up and the engine dies as the clutch is released.
Jerry
09-02-2003 17:39:10
 Re: 1945 VAC stuck in 4th gear in reply to Gary Cash, 09-02-2003 14:34:17
Gary, What it sounds like to me is that the shifting fork broke or something came loose.
Pull the trans cover off and look in to the gears and see if everything is good ,not broken
Gary Cash
09-02-2003 23:02:35
 Re: Re: 1945 VAC stuck in 4th gear in reply to Jerry, 09-02-2003 17:39:10
Jerry,
Will do, Thank you and dctom.
