case 311
Dave in WA
09-09-2003 08:26:18
I have been looking at a case 311 the hood says 300 It has been sitting the last 2 years and he can't get it to turn over It comes with a 5' woods brush cutter and a 5" ferguson corperation tiller it also has the 4spd with high and low gears I will drag it home tonight for $500.00 Are thses good tractors and how are getting parts? thanks for any help
Keith A NNY
09-11-2003 15:34:14
 Re: case 311 in reply to Dave in WA, 09-09-2003 08:26:18
My 311b has been in my family since new in 1959.
It has the case loader model 191 not much info on it nor do you see many around. Mine was pretty tired, I have over $2500 into it and not done yet.
Of course as a family "heirloom" I am doing more than I would have if I just wanted it to run. I do have the original owners manual and the local dealer went hunting in his old books and copied me the parts manual, sometimes things just amaze you.
Don
09-09-2003 10:49:22
thanks for the feed back I will have to get it going and see how it does. Did you say you have a loader on it Iwas interested as to where it mounts on the tractor? do you have any pics? I would like to see I will keep you posted thaks for replying Dave
DON
09-09-2003 11:09:23
 Re: Re: case 311 in reply to Don, 09-09-2003 10:49:22
Yes you can e-mail me at ragmop87@aol.com I would like to get a loader or make one I have a older backhoe unit I want to put on the back its an old Sherman power digger 54 I have it on a smaller tractor and wanted the 311 its heavier than the one I have it on a 2n Yes extra weight on the front
Don
09-09-2003 10:56:26
I don't but send me your email address and I will try to get some to you in the coming weeks, my grandkids have a camera.
The loader case had made for this tractor has the easiest simplest mounting system I have ever seen on a 50's and 60's tractor. I think there are 4 solid mounting areas. The back axles and the front end above the front axle mount.
In 30 years I have never seen a 311 with this case model loader that is all original.
Terry
Don
09-09-2003 10:32:53
I have had one for 33 years, never broke it apart, and it has lots and lots of hours and lives outside!
Its a great tractor, wish mine had power steering!
We use it for general purpose: move dirt, left tractor and combine tires, engines, grade the road, spray seeds, move snow, becuase of the two hydrolic hook ups we can move implements with it, (has a lot of road miles on it) and so on. Baled some hay with it once, did great!
Always starts, always runs, lots of power. Had to put a external engine heater on it.
Never had problems with parts.
There are a few things to tinker with as it gets old, gauges, radiator, steering linkage and so on.
Going to have to go through the brakes and hydrolic pump one of these days.
Always wanted to move the hydrolic levers from under the seat to some place else, never did. It has a case loader on it, can't remember the model, always wanted to widen it! It would be really simple to do and add another hydrolic on the bucket, never did that either, works fine the way it is.
I like that eagle hitch system, compared to the fords and JD. Putting on implments, I didn't have to get off the tractor unless it required the 3 point!
Since I found this web sight, there are more parts and people that own them, know the tractor inside and out and parts available then I thought. Out west here there are very few 300's, 400's or old case equipment in general. Seems in the midwest and in the new england states their is a lot of case stuff looking at this site. I think the reason we don't see many back here is becuase of the large wheat farms we have. Up here in eastern washington the dominent implement dealer back then was AC and JD, now its JD and a little ford and MF. I found mine in 1973 on a JD lot in southeaster WA paid $600.00 and they delivered it to me 250 miles away.
Good luck with your 311.
Terry in Spokane
09-09-2003 10:41:02
 Re: Re: case 311 in reply to Don , 09-09-2003 10:32:53
Don is right, don't see many of them around here and becuase of that they don;t bring the money then should, compared to the 1,000's of 8 and 9n stuff!!!!
I have a 311 for about 15 years and its great, wish mine had power steering, espically when using the loader!
Dave where are you located?
St. John hardware in Edwall,WA has a parts guy that fines my parts or I get them off this site.
Good luck
Terry
Terry
09-09-2003 10:53:40
 Re: Re: Re: case 311 in reply to Terry in Spokane, 09-09-2003 10:41:02
I live in woodinville about 25 miles east of seattle I grew up on a farm there and we sold it years ago but the tractors arre always fun to own and I use them on some side jobs
C. Amick
09-09-2003 09:54:10
As far as I know, you can get engine parts. The price was certainly good. I paid $1,600 for just the tractor. It was running, but needed repairs. It has been a good tractor. Just hope the engine block is not busted.
