430 Case Hydraulics?Lift
Tim Sigmon
05-09-1999 11:39:21
The three point hitch lift on my tractor works great going up and holds the position real well but wont go down unless there is a lot of weight on the implement. With the box scrape, post hole digger or bush hog it goes down fine but with the scrape blade or scoop pan (empty) it won't go down unless I get off and go around and push down on the implement . What need to be done to fix this problem?
Thanks,
Tim
