148-164 engine swap
jon
09-10-2003 18:42:36
Ive got a 300 b with a 148 engine and want to put a 164 out of a 600 b in. will this bolt up easly? thanks jon
martin in De.
09-11-2003 17:16:26
 Re: 148-164 engine swap in reply to jon, 09-10-2003 18:42:36
jon,just went out and measured the back motor flange on a 300 and 400B. The two lower bolts are about an 1.75" wider apart on the 400B. I have read were people have put 201 combine engines in VACs but I will bet it was not real easy,or it was a bitched up job.
dctom
09-11-2003 18:08:36
 Re: Re: 148-164 engine swap in reply to martin in De., 09-11-2003 17:16:26
I DID IT AND IT WAS A PIECE OF CAKE AND IT WASNT BITCHED UP DCTOM
martin in De
09-11-2003 18:30:43
 Re: Re: Re: 148-164 engine swap in reply to dctom, 09-11-2003 18:08:36
Tom,which one of swaps did you make, the combine engine in the VAC or what.
dctom
09-11-2003 18:37:18
 Re: Re: Re: Re: 148-164 engine swap in reply to martin in De, 09-11-2003 18:30:43
yes 201 combine engne in a vac, would send pic of it if i had your e mail addy tom
martin in De
09-11-2003 18:56:58
 Re: Re: Re: Re: Re: 148-164 engine swap in reply to dctom, 09-11-2003 18:37:18
Tom, is the bolt pattern the same on the rear engine flange,I know the starter bolt pattern is different. the engine is longer,did you length the hood. what starter ,flywheel and clutch did you use. And did you have to cut out the bellhousing for the starter.
dctom
09-12-2003 07:10:17
 Re: Re: Re: Re: Re: Re: 148-164 engine swap in reply to martin in De, 09-11-2003 18:56:58
MARTIN IN DE,OK HERE IS WHAT I DID, TRANSFERED HOLES FROM BELL HOUSING TO ENGINE AND REDRILLED ENGINE BLOCK, BLOCKED OFF ORIGINAL HOLES IN BLOCK, HAD FLY WHEEL FROM VAC RE DRILLED TO FIT THE 201 ENGINE, KNOCKED OFF THAT RING FOR STARTER AND GROUND ALL OUT SO VAC STARTER WOULD FIT IN ORIGINAL VAC LOCATION, USED VAC FLY WHEEL AND CLUTCH, THAN GROUND OFF THE ENGINE FLANGE TO MAKE NICE LOOKING JOB, YES LENGETHENED HOOD AND DRAG LINK 3/4 INCH, ALSO USED VAC GOVERNOR AS 201 HAD BELT DRIVIN GOVERNOR, IF YOU ARE IN DELWARE(if that is what de is for) THAT TRACTOR WAS IN NJ AND MAKE A BIG HIT AT PULLING CONTESTS. IT IS NOW IN ILL AND IS A 224 ENGINE NOW AS GUY HAD IT ALL WORKED OVER AND MADE INTO A 224 , VAC WITH 80+ HP I HAVE A PIC AND WOULD SEND IF I HAD YOUR ADDY, I DONT KNOW HOW TO POST A PIC HERE DC TOM
martin in De.
09-10-2003 19:23:04
jon,500b,600b and 400b engines will interchange,but the bolt pattern is different for the 300/300b.
Terrance
09-11-2003 11:04:00
 Re: Re: 148-164 engine swap in reply to martin in De., 09-10-2003 19:23:04
The 300/300B and the 400B use the same engine, a G148 cu in and the bolt patterns are the same.They both have two bolt pattern starter. I dont know about the 500B or 600B, but if the 164 Cu in engine has the two bolt starter I believe it should fit with no problem.The problem is using the later G148B engine which has the three bolt starter.Hope this helps
Terrance
martin in De.
09-11-2003 15:43:10
 Re: Re: Re: 148-164 engine swap in reply to Terrance , 09-11-2003 11:04:00
terrance,the engine in the 300/300b and 400b are 148 cid,but the blocks are different.
Terrance
09-12-2003 06:04:17
 Re: Re: Re: Re: 148-164 engine swap in reply to martin in De., 09-11-2003 15:43:10
Martin,
I have a round nose 300 with a dry clutch two bolt starter,I also have a 400B with Case oMatic it also has a two bolt starter both engines are the same the bolt patterns are the same.I know that the lower bolt pattern is the same on mine for sure because I just transferred the front axle from the 400B to the 300 complete including the support that bolts to the lower bellhousing.Maybe there was a midseries change in the B series and if so that could account for the difference you are showing.
Hope this helps.
Terrance
