identifying a VAC without the tag?/
maple hill frm,
09-17-2003 21:27:09
is there a way to identify a tractor , I believe it is a vac wide front end,, at least this is what I was told, the serial tag on the steering colomn is gone,,, was hoping of a way to find out exactly what I have,,pat
VAI-GUY
09-24-2003 05:02:34
 Re: identifying a VAC without the tag?/ in reply to maple hill frm,pat, 09-17-2003 21:27:09
On my VAI there is a tag on the front of the left side axle housing. It tells the date, which the tractor was made,or the date which that piece was cast.
Art
09-18-2003 03:47:53
You could have a VA,VAC14,VAC13 or a VAI. All of these models were availible w/ a wide front end. A couple of pictures will help alot.Is the width of the front ajustable? If it is, it's a VAC13, or 14. If not then its a VA, or a VAI. to tell those two apart, look at the front axle. If it's a solid 1.75x3., or 2.x3. you have a VAI. If its 1.25 thick, it's a VA. Also the shifting pattern on a VAI is what called a "highway pattern" or an "H" pattern. If first and second gear are side by side, its a VA. Hope this helps....
Art
09-18-2003 14:29:18
 Re: Re: identifying a VAC without the tag?/ in reply to Art, 09-18-2003 03:47:53
Your Welcome
pat
09-20-2003 05:46:54
 Re: Re: Re: identifying a VAC without the tag?/ in reply to Art, 09-18-2003 14:29:18
wow, I was just getting back, and I was going to get a picture to help, I always try to say thanks to people that have helped me out and you have thanks,Pat
